2012017 corvette C7 LT1 Tool needs update. (Wont update)
Tomkat2800
Post by Tomkat2800 »
Uninstalled T1000 from 2105 Dodge Challenger SRT 392. Went to tune my new 2017 Stingray LT1. Tool says it needs an update to tune this vehicle. When connect to DSDL it says "Communicating with ignition?" Anyway it updates nothing and ends with an error, (Don't have permission).
Searching the forums I think the tool may need a reset, based on similar situations. I have downloaded the latest USB drivers and DSDL software.
Unmarried
GM CAN gas
1r14a
born 12/14/2017 41846
Based on other posts I supply the following key. I will leave tool powered up until I hear from you.
B829-878B-2CD0-C320-3664
Thank you and I look forward to tuning my new 'Vette.
Tom.
:D
2017 Corvette Stingray Coupe. w/1LT. LT1. 7 Speed. Corvette Racing Yellow Tintcoat. Performance Exhaust. Black wheels. Yellow Calipers. Window tint. T1000. Z51 rear sway bar. Skip shift eliminator.
Tomkat2800
Re: 2012017 corvette C7 LT1 Tool needs update. (Wont update)
I spoke with Tech support this morning. They said there was a problem with a server on Diablosport's end.
I was told to try again later.
I look forward to tuning my new car.
Thanks.
Tom.
sorry for the delay, we're working to get this fixed asap.
Tomkat2800
Thank you.
It looks like it worked on my last attempt this afternoon.
Now that I can see the tunes available, I want to buy the AFE CAI!
:D
Thanks again.
Tomkat2800
May not be working yet. Will advise.
Tomkat2800
First attempt failed. (I believe the ignition powered down) Install original backup. Had to update tool again.
I installed the Diablo tune, then modified it as desired. Car started. No check engine light.
I scanned all systems and found a U0100 in Chassis control module. (I have a manual 7 speed)
Do you advise my taking any further action for this code? When selecting vehicle I did change the trans type to manual.
(That was several days ago)
I will try it as it is. I wonder if this will affect my skip shift warning!
I love working on cars!
Thanks for your help!
Tom.
:wink:
Tomkat2800
On first test drive I see that the gear indicator does work. Amazing, I still have not seen the Skip Shift notice. I will work it out. Car felt very good. Good tune.
the code should clear itself, wouldn't worry about it.
Enjoy!
Return to “Trinity GM Gas”
