question on new revision
bob34787
Post by bob34787 »
just installed new 03 revision and had a few interesting moments.
1. after backing up the original headlights stayed on
2. when updating trans functions tuner froze
3. unplugged tuner and started car, car started but stalled after a few seconds. repeated process and car ran.
4. reattached tuner and started all over, this time everything went as it was supposed to.
maybe it was just a brain fart on my cars part but I thought I would let you know.
RE: question on new revision
Odd....let us know if it happens again.
bob34787
Post by bob34787 »
will do. one other note, the tuner stopped working at the trans function. I could hear the click from the pcm and it just stopped at that point. second attempt went fine.
bob34787
Post by bob34787 »
well I just reinstalled original and redid the installation and the same conditions pop up as noted before. It stops at the key on/off under mode 2.
bob34787
Post by bob34787 »
it seems atleast on my car that after you do the backup you have to turn car off unplug tuner, that plug in tuner, turn car to on and than install tune
We'll look into this in the morning.
bob34787
Post by bob34787 »
thanks.
dsom16
Post by dsom16 »
Strange issues with this and 9R02 also. got a -10 return code, stating performance tune was already installed (it was stock). had to retry several times to get tune to load. The older releases of tunes (the 8 series) were much more reliable and I never had issues. THese 9 series give me all kinds of fits loading
kymag
Re: question on new revision
Post by kymag »
bob34787 wrote:just installed new 03 revision and had a few interesting moments.
My 2008 did the same thing.
bob34787
RE: Re: question on new revision
Post by bob34787 »
well All i did was unplug tuner and reboot and the new tune and paddle hold work fine.
fordomatic69
Post by fordomatic69 »
Same Kinda thing happened. Running 89 octane right now so all I wanted to do is increase shift firmness and up the shift points with rev limiter on the stock tune. Predator froze while updating shift firmness with 9r03 (right after the key off/on procedure the hourglass came on and that was it). Airbag light and check engine light stayed on. Started Car, shut off car, unplugged Predator, turned key on, plugged in predator, restored factory tune to be 100% sure everything was good, updated shift firmness okay this time, upped the shift points (rev limiter too) okay! I think there might be a small bug-a-boo on the trans functions.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
bob34787
Post by bob34787 »
yes it only happens after you take your original backup and go directly to the diablo tune. I did it twice with same result. It works fine as long as you unplug the tuner after taking your original backup and than plugging it back in,than install the tune and trans. function you want.
fordomatic69
Good job on figuring this one out. :)
Fordomatic Says:
johan
Post by johan »
We saw this issue here this morning, will be addressed in next update.
For now just go ahead and install tune first then do the quick adjust, this will only happen after you take a backup and attempt to adjust quick adjust.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
johan
Post by johan »
9r04 is up to remedy this issue.
Diablosport INC
