Predator 2 for 2017 Silverado 5.3L
What adjustments are available on the Predator 2 for 2017 Silverado 5.3L w/6 spd trans?
McSoloNick
Re: Predator 2 for 2017 Silverado 5.3L
I would go with trinity 2 because you can monitor gauges I have the first gen trinity T-1000 I haven’t had any problems with it... it’s fun you can disable AFM as well as adjust Injector slopes, PE at WOT, Timeing( Spark Advance and Retardation) vehicle speed limiter, rev limiter in gear, engine speed and idle and neutral etc for your ECm and for your TCM you can change shift points and shift pressures at WOT and part throttle and you can adjust same parameters for your Overdrive button, adjust gear ratio, tire size, and disable torque management! Pretty much sums it up you probably can do more but that’s all I can remember off the top of my head. Its worth it if you want to have a little fun and learn more about how your engine really works. I had a 13 Silverado 5.3L LT just totaled it 2/28 so I’ll sale you my first Gen if you’re interested I did tune my truck back to original once I went to get my tag and personals from the wrecker yard. So you won’t have to worry about that. It’s up to date so you’ll just have to plug it in and pick whatever time you like. It’s still has the plastic on the screen pretty much brand new still because it stayed in the window of my truck 98% of its life.
and you can not do custom tuning with a predator..
you'd want the inTune i3 8245 Platinum/Pro, or the Trinity T2 EX 9245 Platinum/Pro...
McSoloNick
Is that the best device to load custom tunes on a duramax or power stroke
No custom tuning for diesel applications unfortunately.
McSoloNick
Okay, does the T1000 work with 2017 F150 5.0? I says only the predator 2 and T2 online but I still have my T1000 from my Silverado? And If I decide to go Duramax or Powerstroke I will only be able to use the Predator 2 with my emissions equipment equipped correct?
Yes, t1000 will work for the 17 5.0
Yes, P2 will be the required device for use on the newer dmax or powerstroke.
