Chevy 4L80E Transmission Pressure setting
Posted: Fri Mar 30, 2018 1:30 pm
by screamingbuick
I've just put the 87 Tune on my 02 Avalanche 2500. It has the 4L80E Transmission, it shifts a bit hard like I'm trying to chirp my tires. I went into custom settings and changed the partial throttle shift pressure down to lowest setting -25 and it didn't change anything. Am I doing something wrong? I'd like to soften the shift up just a little bit. Awful heavy truck and I don't want to break anything. The transmission had a full rebuild about a year ago.
thanks,
Bob
Re: Chevy 4L80E Transmission Pressure setting
Posted: Fri Mar 30, 2018 3:11 pm
Im guessing it was rebuilt a bit better than stock to add some mechanical line pressure?
Maybe a shift kit? Valve body mod?
Posted: Fri Mar 30, 2018 5:09 pm
by screamingbuick
No its a totally stock rebuild, the original transmission I had to drive 500 miles pouring in transmission fluid as fast as it squirted out to get it home to fix the leak. It lasted about 6 months before it quit, that when i had it rebuilt. With the stock tune you cant feel it shifting at all, really smooth.
Posted: Sat Aug 18, 2018 3:21 pm
by RustyBawz
I'm in a similar position with the shifting, except no rebuild, still original trans (I believe) and 91 octane. I tried playing with the shift time with little success. It's my daily and I don't want to have to do a rebuild if I don't need to. 220k miles...
Although, when I do give it everything, that quick, hard shift is beautiful.
Posted: Sat Aug 18, 2018 7:03 pm
by screamingbuick
Same here, I paid a lot for the nice transmission rebuild, not worth it for the chirping of the big tires, haha.
Posted: Thu Nov 15, 2018 12:18 am
by DeathStar6
Hey, guys...
I guessing I going to run into this as soon as I get my T2 EX working right. I was wondering if anyone has found a solution for this problem?
Posted: Thu Nov 15, 2018 12:31 am
by 06MonteSS
lower the shift pressure by -20%, and turn the torque management ON/Enabled...
Posted: Thu Nov 15, 2018 1:28 am
by DeathStar6
06MonteSS wrote:lower the shift pressure by -20%, and turn the torque management ON/Enabled...
Thank you, I let you know when I finally make it to that point, how it worked out.
Posted: Tue Dec 25, 2018 3:33 pm
by mattmudden
I have the t2 but i Wish i would have found this sooner. But rear seal is what happened to me and my dumbass listened to master mechanic and used the black silicone to seal the "rear housing" brand new bushing and whatnot. But now something else gave and my truck is rotting in drive way.
