Additional license
koufeman
Additional license
Post by koufeman »
I purchased an additional license through the Ignition Updator and my new Trinity T2 still only shows that I have 1 license available/1 used.
Should my tuner info not show 2 total licenses with one used from doing an update to it and purchasing the additional license?
My order number is 700006645 from Ignition
here is my
info.xml
file
koufeman
Re: Additional license
Post by koufeman »
Bump awaiting for the mods to answer
have you run the Ignition Updater again after purchasing the additional license?? once the license is generated on diablo's end, you need to run the Ignition Updater program again on the tool to update it with the license info..
please update again and it will be added.
koufeman
Post by koufeman »
I had updated the T2 three times after buying the license.
I will try updating the tuner after I get home and let you know if it shows a second license available.
EDIT: I updated the T2 and it shows the 2nd license available. Thank you for your assistance. :D
