Every time I connect my Intune I3 to the Ingition Updater it keeps telling me Updates are available for your device. Do you want to install them now? It keeps installing Diablo Master r25 (2 files). Serial # is 201111055. On the Pop Up at the bottom left it indicates Up to date version 1.53.30301.31493
On the Intune I3 screen indicates, The I3 Installer preparing, then installer in progress, then verifying, then updates have been installed, press continue to reboot device, after reboot the ignition updater indicates Your Device is now Up-To-Date.
If I unplug it and plug it back in it goes through the same process? When will this glitch be corrected?
I3 Ignition Updater
I3 Ignition Updater
2021 Ford F150 SC XLT 3.5 EB Sport Fully Loaded
I3 and Predator P2 Platinum
Re: I3 Ignition Updater
Looking into it, but if it updates once, no need to do it again
