E85 custom tune
E85 custom tune
Does anyone do custom tuning with e85?
Re: E85 custom tune
flex fuel truck or no?
Re: E85 custom tune
I have added the sensor. So it needs to be activated and tuned for it.mikel wrote:flex fuel truck or no?
Re: E85 custom tune
contact Andy at [email protected] he does e85 tunes..
Re: E85 custom tune
Sweet thanks bro! I was going to get ok next from you. Been then I installed the flex fuel sensor06MonteSS wrote:contact Andy at [email protected] he does e85 tunes..
Re: E85 custom tune
yeah, I don't do anything for e85...
lschafroth
Re: E85 custom tune
Do you do any tunes for E15? It is a 88 octane and the price is only $1.92 right now. I have your custom 87/89 Tune and your 91/93 Tune. I wasnt sure if there were any gains to get from the E15 or if it's treated like normal octane.06MonteSS wrote:yeah, I don't do anything for e85...
Your 87/89 Tune runs quite well on it. I switch from E85 to E15 during the winter. E85 is pretty hard to start when it's really cold.
Lannie
Re: E85 custom tune
you can use the current tunes you already have with that e15....
lschafroth
Re: E85 custom tune
Thanks for the quick reply! Sounds good. It does run good on the E15 and I still get decent MPG.06MonteSS wrote:you can use the current tunes you already have with that e15....
Lannie
Re: E85 custom tune
I was told you can't use an E85 flex fuel kit on a 2018 Camaro SS LT1, is this true?
Re: E85 custom tune
You can, along with the needed bigger fuel pump and injectors, and then take it to a shop to get tuned with HPTuners, and they can send your TCM to HPTuners too to get it unlocked/modified, and then they'd be able to tune your A8 tranny too with hptuners.18SS376 wrote:I was told you can't use an E85 flex fuel kit on a 2018 Camaro SS LT1, is this true?
Re: E85 custom tune
I already know this, was asking if it can be done with my i3?06MonteSS wrote:You can, along with the needed bigger fuel pump and injectors, and then take it to a shop to get tuned with HPTuners, and they can send your TCM to HPTuners too to get it unlocked/modified, and then they'd be able to tune your A8 tranny too with hptuners.18SS376 wrote:I was told you can't use an E85 flex fuel kit on a 2018 Camaro SS LT1, is this true?
Re: E85 custom tune
Yes, custom tune can be done to enable the flex fuel sensor with cmr.
Re: E85 custom tune
mikel wrote:Yes, custom tune can be done to enable the flex fuel sensor with cmr.
i have a 2018 silverado with the diablo tune and was recently looking up about doing the flex fuel sensor conversion and i read in a forum that once u plug in the pigtail connector to the sensor the ecu will recognize it and make the adjustments ? how true is that?
Re: E85 custom tune
Not true at all.
Sensor has to be enabled inthe tune so the pcm knows to look for it, and then there may be several tables that need to be populated with realistic data to make it all work properly.
