Data Veiwer problem
sunoka
Data Veiwer problem
Post by sunoka »
When I connect to the H/H u7140 the Data Veiwer to record some data logging it indacates there is a connection and when acquiring tool information it then tells me Problem Detected ?Then I am unable to record any data.
Update I left the computer connected and got a message:
Shutting Down Connections
Failure to retrvieing Tool Information
Please Reboot and consider updating your tool firmware.
johnc
RE: Data Veiwer problem
Post by johnc »
Is your predator revision 8r38? You can find this at the top of the main menu.
If not, you need to update your Predator CROM.
johnc <at> diablosport.com
sunoka
Re: RE: Data Veiwer problem
Post by sunoka »
johnc wrote:Is your predator revision 8r38? You can find this at the top of the main menu.
No v.8r31
Were can I find CROM updates ?
johnc
RE: Re: RE: Data Veiwer problem
Post by johnc »
Click the Support button above, select Downloads. On that page select U7140.
The good news is you should be good-to-go once you update.
sunoka
Re: RE: Re: RE: Data Veiwer problem
Post by sunoka »
johnc wrote:Click the Support button above, select Downloads. On that page select U7140.
I have these updates and which update would you like me to update.
johnc
RE: Re: RE: Re: RE: Data Veiwer problem
Post by johnc »
You need to install DS Downloader.
Then you need to download the latest CROM file.
Then follow the instructions in the DS Downloader help file to update the CROM to the Predator.
Return to “DataViewer/DV2”
