Need PCM calibration following truck recall
P40Hawk
Post by P40Hawk »
2014 Ram 2500 power wagon. I returned the truck to stock before the recall appointment at the dealership. Once I returned and tried to reinstall the diablo tune it is telling me the PCM needs to be recalibrated. I tried to update the handheld but no updates are available. attached is the .xml file.
One of the recalls was to update the PCM from 68153865AG to 68153865AK If that helps.
info.xml
(1.8 KiB) Downloaded 532 times
Re: Need PCM calibration following truck recall
connect the device to a pc and run the ignition updater program and it will download the file you need then you can load it to the vehicle then tune it.
P40Hawk
Post by P40Hawk »
Thanks Mike,
The auto Updater worked this time. However, there was an error during the PCM recalibration and it failed. Now the handheld is in recovery mode. What do you want me to do now? I have tried it three time with the same result. It progresses through 100% then circle of death until it states an error has occurred.
info.xml
(1.73 KiB) Downloaded 516 times
