N2O Tuning for2016 Mustang GT
Need help pulling timing with the Trinity in my Mustang. Do I need to modify the stock tune? Or modify the canned tune? Should I adjust Global spark or the WOT Spark? Or Both? Do I need to load a specific nitrous tune to use the N2O or can I use the canned 93 tune with WOT spark pulled and still drive on that tune when not using N2O? Need some help here as I do not want to blow up due to timing being too advanced! Is there someone out there that will write a specific N2O tune that can also be driven on daily for the Trinity 1000? If So I can't find them? Lots of questions hoping for some solid answers here!
Re: N2O Tuning for2016 Mustang GT
A custom tune is certainly an option.
Beyond that you can use the WOT spark adjustments to pull timing for use on the N2O.
Proper method would be to log it with the tune as is to see total timing at WOT, then make the adjustments and log it again to confirm the changes you made are working as expected, and then spray it
