I have a JEEP TJ AVE brute with a stroked 6.1 to 6.4 Arrington the wire harness and the ecu is from Hotwire the car has been running rough since I bought it I have run several diagnosis on the engine all I found is nothing that concerns/impacts engine health, checked the Engine for air leaks non found also replaced a new fuel pump unit with the assembly, I'm almost certain that my issue is related to an ecu proper tuning i just need someone to look @ my log files and determine weather its a tune related issue or mechanical issue.
I ran a diag scan no trouble codes related to engine`s health i have SKIM DTC and transmission gear ratio being incorrect + Fuel level sensor, Yes i could smell fuel i also noticed "THR POSN" not working and DELTHR PID is working fine not sure if that could be an issue.
Your help is appreciated
6.4 LTFT STFT dilemma
- TJ Brute Logs.rar
- (763.48 KiB) Downloaded 327 times
Re: 6.4 LTFT STFT dilemma
was it custom tuned for the 392 or is it running a standard 6.1 file?
The pcm is MY05 custom tunedmikel wrote:was it custom tuned for the 392 or is it running a standard 6.1 file?
After going through the logs i noticed that when the truck goes @ WOT the AFR gets @ 11.12/13.70 the LTFT STFT get smoother and almost perfect closer to 0. please check my log labled " Highway driving part 1"
Strangely enough on the "Coldstart log" some injectors stop working noticed that takes place when AFR is @ 14:41 both STFL 1/2 are happy with a value of 0. please check the attached images.
- cold start 3x injectors PW CYL 0.0 2.JPG (109.44 KiB) Viewed 3401 times
- cold start 3x injectors PW CYL 0.0.JPG (124.22 KiB) Viewed 3401 times
6 4 LTFT STFT dilemma
Hi,
While tuning idle and close above I noticed that AFR was slightly rich of target and STFT was correcting by removing fuel but simultaneously LTFT kept adding fuel.
Am I missing something here or is it a bug?
