Nitrous SRT8 Question
srtbrian
Post by srtbrian »
I havent seen any one answer this, so here it go's dose nitrous work better and is it better on the engine if you do have the timming retarded, as before diablo had a programer for our cars we would run nitrous on the stock PCM. Or did it retard it like what we are doing manualy with the programer? Also when you click on rase shift points it dosent tell you what it rased it to. How do I know?
RE: Nitrous SRT8 Question
Yes, you should pull some timing with the N20.
If you have a 5.7, you can select 6000 or 6400 shift points, an a 6.1 they are raised to 6400.
dynosteve
Post by dynosteve »
the old try'd and true rule for taking timing out on a nitrous system was 2 deg's for every 50hp of nitrous used, i've always found this to be pretty close depending on the fuel octane your using
RDP Motorsport Ohio
