AFR reads 17+ at WOT on my predator
owlick
Post by owlick »
I have the SLP7190 for my 05 GTO and when I try to read with DSLogRedux it says I did not make a WOT run. I know I did :? . When I check the log file it shows AFR around 17 at WOT. It used to show around 12. I am thinking this may have happened after I updated to 8r07. I searched here but didn't see anything about this. LS1GTO had something and I saw that subtracting the difference from 14.75 AFR, which is my normal cruise AFR, would give me the correct WOT AFR.
Is this correct or is there something I need to do to fix this issue.
Alec
RE: AFR reads 17+ at WOT on my predator
yeah, you need to invert the AFR data in the dataviewer first, before you save it as a csv...
in the dataviewer, when you have the log loaded, go up to the top menu:
VIEW > PARAMETER MODIFIERS > E40 EQUIVALENCE RATIO-INVERT
that will invert your WOT AFR data to the correct values.
THEN save the log out as a csv file.
owlick
Post by owlick »
Ok thanks!
Wonder why it has all of a sudden reverted those numbers. It was working for a time.
if you updated your version of the dataviewer, it probably reverted the settings back to the default of not doing that.
Return to “General Support”
