MDS
Theskitzofrantic
MDS
How do I disable MDS on 2007 Dodge Ram?
Re: MDS
select the tune then choose the modify tune option then go to MDS and set it to off.
Then back up and select apply tune.
Re: MDS
Hi Mikel
I’m having same issue.
My MDS won’t turn off.
It originally did when I first loaded tune near 12 months ago, into my 06 300c.
Got new tyres today and went in to adjust tyre ratio.
Thought I’d also change a few other things like throttle and rev limit ect.
Checked to see if MDS was turned off and “ON” was highlighted *
So pressed “OFF” and backed out and loaded tune.
Went back in and it still says “ON”.
I did an update on my i3 last night via computer.
Would that have anything to do with it.
Cheers
Cheers
Re: MDS
I read elsewhere on the forum.jweil88 wrote:I am having the same problem 2006 dodge charger r/t mds on always has asterisk by it will not switch to off intune i3
As long as MDS has the Astericks then it’s turned off.
