help trying to programm a silverado previous truck f150
Posted: Wed Oct 17, 2018 12:59 pm
by juangorena
I sold my F150 , so i tried to use my programmer but it don let me , i updated it to gm crom , but i think that it have another file atacched to ford , it keep showing that the tuner needs to be updated via dsdl it have the latest gm crom but when it reads the vin says it need to be updated
t1000 serial 6OBTY1D-3
VIN 3GCUK9EJ0JG345785
THANKS FOR YOUR HELP :D
Re: help trying to programm a silverado previous truck f150
Posted: Wed Oct 17, 2018 1:46 pm
did you restore the original backup stock tune to the Ford truck in order to unlock/reset the Trinity??? if you did not, then it is still locked to your ford and you can not use it on the silverado... you'll need to contact tech support...
Posted: Wed Oct 17, 2018 1:55 pm
by juangorena
Yes i did , the programmer shows Trinity not married yet / Nothing to show i also used .frg files in the past , wondering if this is not causing the problem?
Posted: Wed Oct 17, 2018 2:12 pm
What's the year, engine of the silverado you're trying to install a tune on?
Posted: Wed Oct 17, 2018 2:20 pm
by juangorena
2018 6.2L i did several updates via dsdl but nothing once i select model and engine it shows tuner needs to be updated
Posted: Thu Oct 18, 2018 12:58 pm
by juangorena
pls help me to unlock the programmer to a 2018 6.2L silverado
IT DOES NOT UPDATE EVEN WHEN THE DSDL STATES UPDATED
Posted: Thu Oct 18, 2018 1:03 pm
2017/2018/2019 vehicles require a special unlock sequence...
With the newer inTune i3 and Trinity T2, what will happen is, when you go to install a tune the first time, the tool will give you a message that "one or more controllers can not be tuned - Contacting powertech for vehicle unlock... you will be notified within 1-2 days" - or something similar to that effect.. so then in 1-2 days (usually within an hour though) you should receive an email (if you registered your tool on diablo's site) that your update is ready.. so then you'd run the Ignition Updater on the tool again, and it will update the tool with the unlock code for your ECM, and then you'd be able to tune the vehicle.
But with the old Trinity T1000, I'm not sure it works the same way, since that uses the DSDownloader program and not the new Ignition Updater program...
Contact [email protected]
