t1000 trouble updating for my 2018 silverado
cokero94
Post by cokero94 »
plug the t1000 to truck and says needs to be updated to tune vehicle but it doesn't let me update it needs a force reg.
the current version is v.1r14b
my trucks vin is: 1GCNKREC7JZ266975
AND MY TRINITY SERIAL IS :6OLSI6D-3
juangorena
Re: t1000 trouble updating for my 2018 silverado
Post by juangorena »
i have the same problem !!
2017/2018/2019 vehicles require a special unlock sequence...
With the newer inTune i3 and Trinity T2, what will happen is, when you go to install a tune the first time, the tool will give you a message that "one or more controllers can not be tuned - Contacting powertech for vehicle unlock... you will be notified within 1-2 days" - or something similar to that effect.. so then in 1-2 days (usually within an hour though) you should receive an email (if you registered your tool on diablo's site) that your update is ready.. so then you'd run the Ignition Updater on the tool again, and it will update the tool with the unlock code for your ECM, and then you'd be able to tune the vehicle.
But with the old Trinity T1000, I'm not sure it works the same way, since that uses the DSDownloader program and not the new Ignition Updater program...
Contact [email protected]
Thanks!
cokero94
Post by cokero94 »
SO WHAT IS THE PROCESS?
as I mentioned above, Contact [email protected]
cokero94
Post by cokero94 »
OH just noticed that sorry, thanks hopefully that works
Return to “Trinity GM Gas”
