i2 last update
i2 last update
I recently updated my i2 and now some things are out of order. For instance the fan temperatures use to go from lower to higher temps. Now it is the attached pics.
Re: i2 last update
we'll check this out but it shouldnt be an issue.
Re: i2 last update
Can you please post the info.xml file from the device so we can check it out?
Re: i2 last update
Here it is.
Re: i2 last update
I see you have 2 VINs here, I need to know which vehicle you see this on please.
Re: i2 last update
The truck is at home. I am not sure which is which I will have to send that when I get home.
