This is my first programmer and it works great. It was very easy to install and the truck is running perfectly.
I installed the 91 easy program with firm shift and turned the AFM off. I'd like to return to the factory shift and keep all of the other changes. Do I need to reinstall the factory tune and start over or can I go back through the 91 process and just change the shift?
Intune i3 for 2014 Chevrolet silverado 5.3 newby
Geraldcook01
Re: Intune i3 for 2014 Chevrolet silverado 5.3 newby
You need to select/install the tunes from the Tune Vehicle - Advanced Mode menu... for the ECM/engine tune, select the "Diablo Tune" if you use 91/93 octane gas, or the "87 Octane Tune" if you use 87/89 octane gas.... then for the TCM/transmission tune, if you want to just keep stock settings, select the "modify stock tune" for the TCM/transmission tune... that is a copy of the original backup stock tcm/tranny tune....
then install/apply the tunes... and that will install the preset canned ECM tune that you selected, and a copy of the stock tcm/tranny tune...
Geraldcook01
So, can I just go to TCM and select modify stock then install tune or do I need to go through the ECM menu also?
I don't think there's any way to install just a TCM tune...you need to go through the ECM process/menu first.
You can install just an ECM tune, but that doesn't help you.
you can click skip for pcm then load only tcm, or vice-versa....
do as I said in my reply... you have to select the Modify Stock Tune for the TCM/tranny tune in order to get your transmission back to stock factory shifting settings at this point, since you already had installed one of the preset tcm/tranny tunes...
if you just skip the TCM tune, it will keep the preset canned tune in there that you already have installed..
you need to select/install the Modify Stock Tune for the tcm/tranny tune in order to get the tranny back to the factory stock shifting settings.
Geraldcook01
I know I need to go to the modify stock tune in the tcm menu. I was wondering if I needed to go through the ecm set up again or could I just skip the ecm setup because it's right where I want it, and go straight to tcm.
Now that I've been running with the firm shift for several days now, I'm getting used to it and will probably leave it alone but just in case it's good to know the proper procedure.
Thank you for all the support, the i3 has really surpassed all my expectations.
skip the ECM tune/module... then choose Modify Stock for the TCM/transmission tune...
that will keep the current ECM/engine tune installed, and will just install a copy of the factory stock GM transmission tune..
Geraldcook01
Great!. I was hoping it would be that simple. I am a master carpenter and pretty good at what I do but I know very,...very little about motors and how to tune them. That's why I chose the Diablo tuner because of the preset tunes. I just wanted to add a bit more power and turn the AFM off on the stock Silverado and the i3 did just that. Very happy with the results.
Thanks again for the help.
lschafroth
I highly recommend getting the LewTune. He will make a custom tune just for your vehicle. The gains over the canned tunes are fantastic.Geraldcook01 wrote:Great!. I was hoping it would be that simple. I am a master carpenter and pretty good at what I do but I know very,...very little about motors and how to tune them. That's why I chose the Diablo tuner because of the preset tunes. I just wanted to add a bit more power and turn the AFM off on the stock Silverado and the i3 did just that. Very happy with the results.
I always made him leave the AFM enabled but I have since disabled it. The MPG did suffer 2-4Mpg but I dont have to worry about the lifter collapse stories and the instant power is a nice plus.
Lannie
