T2 problem Jeep Wrangler
kachni.pero
Post by kachni.pero »
Hello,
I recently bought Magnusnon supercharger, with it i get T2. I went step by step according to the manual, upgrade T2 through Ignition (twice) when I connect it to the vehicle and tap on Tuning I get this msg "There are Control Units in this Veicle that are currently not supported...." so i tried to update once more and it is stuck on updating 2/2. I tried it several times, it's still the same. Adding info.xml
Re: T2 problem Jeep Wrangler
theres an issue with our server, it should be resolved shortly and you'll be able to get the updates.
kachni.pero
Now i tried update it once more this is what i get
copy this to the t2 drive and let the device import it then load the update to the jeep then you can tune it.
