I have been doing some logs and for some reason my LTFT is stuck at 1. It doesn't change dependent on speed or engine rpm or engine load. I have PO2270 and PO2272 showing bank 1 and 2 lean. So I was trying to see how lean I was running. Does this sound like bad O2 sensors? I tried to log some of the O2 sensor information but I am not sure which one I should log. I can do a log tomorrow and upload then. Just checking what all I should log.
Thanks!
Long Term Fuel Trim
Re: Long Term Fuel Trim
I fixed this myself as well. Apparently now the i2 has 2 sets of LTFT I have to select when I log. One seems stuck and the others respond.
