well, title said enough, just installed Vortech kit but T3 comes with kit says
This Vehicle is not supported.
I update with wifi for 3-4times, finally said updated but still saying not supported.
please help
mustang 2004GT doesn't connect T3(vortech)
Re: mustang 2004GT doesn't connect T3(vortech)
its asking you to connect to a pc and check for updates with the ignition software then load the update to the car then it should let you tune it.
Hawaiizuka
Ignition software doesn't wanna do nothing and just say there is no updates.mikel wrote:its asking you to connect to a pc and check for updates with the ignition software then load the update to the car then it should let you tune it.
Should I try factory reset and try update with ignition software?
do I lose tune fro Vortech? if so, can you tell me how to take back up?
Thank you
please post the info.xml file from the i3 drive so we can check it out.
Hawaiizuka
here it ismikel wrote:please post the info.xml file from the i3 drive so we can check it out.
ok heres the quick fix.Hawaiizuka wrote:here it ismikel wrote:please post the info.xml file from the i3 drive so we can check it out.
I am going to convert this to a normal i3.
it will allow you to update the pcm and read the backup then you'll email that file to Vortech and ask them to apply a tune for your kit and they can email it back, and you copy it to the device to load it up.
Please update the device 2x with ignition to complete the conversion.
Hawaiizuka
mikel wrote:ok heres the quick fix.Hawaiizuka wrote:here it ismikel wrote:please post the info.xml file from the i3 drive so we can check it out.
I updated and finally flashed this time, I'm waiting for Diablo guys to reply email now.
which file should I sent them?
you'll send vortech the backup file from the tunes folder on the device.
