Air fuel ratio
Posted: Tue Jan 01, 2019 1:32 am
by dodge59
Hello does the A/F ratio show up on the predator so i can fit a new throttle body which if it works properly should lean out the motor
and can i adjust to suit
Regards Mike
Re: Air fuel ratio
Posted: Thu Jan 03, 2019 11:55 am
Well, you didn't say what vehicle....thats gonna be key.
Re: Air fuel ratio
Posted: Thu Jan 03, 2019 6:57 pm
by dodge59
Sorry Mike
2008 Chrysler 300c 5.7 93 oct cai tune catch can magnaflow exhaust cat back brisk plugs
Thanks mike
Re: Air fuel ratio
Posted: Fri Jan 04, 2019 3:59 pm
No, you need to add a wideband O2 sensor to see AFR on that vehicle. A throttle body is not going to lean you out. Bigger concern is the potential driveability issues that can come with an aftermarket or ported throttle body that will require custom tuning to fix.
Re: Air fuel ratio
Posted: Fri Jan 04, 2019 5:25 pm
by dodge59
In that case Mike i will leave well enough alone
THANKS FOR YOUR HELP
Regards Mike
