2018 Charger OBD Gateway Bypass
mliddell
Post by mliddell »
Just picked up a T2 and PCM.
Going through the OBD gateway bypass instructions I can't find the Green connector bank on the Type B Installation.
Any tips on where this is? The picture on the instructions is not a 2018 charger.
aclay
Re: 2018 Charger OBD Gateway Bypass
Post by aclay »
Same issue on 2018 Demon- only white block- plugging in the green connector does not work..
aclay
Post by aclay »
Figured it out!! On the passenger side below the glove box, is the proper green port- just pop out a couple christmas tree pins and there it is- run the cable back over to the driver side OBD port and good to go- Remember to Thank Adam from Authentic Performance... i wasted an hour figuring this out...
Sorry about that, we;re in the process of putting together some better documentation for these different locations across vehicles.
mliddell
Post by mliddell »
Thank you Adam! I was scratching my head.
