can someone help me
can someone help me
cannot adjust the PE on the DSLogRedux. downloaded the new version it just says no data. my AFR is 14.75 and i know it is high. it also shows no WOT data points. if any one an help it would be very nice. my truck is a 2007 gmc sierra vmax 6.0
Grumpy_Aero_Guy
Re: can someone help me
Are you using the latest version (4.3.3). If not, please download it. You can check via Help-->About when it is open.cgray wrote:cannot adjust the PE on the DSLogRedux. downloaded the new version it just says no data. my AFR is 14.75 and i know it is high. it also shows no WOT data points. if any one an help it would be very nice. my truck is a 2007 gmc sierra vmax 6.0
If you have a csv file generated from your log, please post it here.
COuld be one of several things going on.
1) If you have LESS THAN 100 WOT data points for either rpm range, that's not enough data. Need at least 100 data points (which is a good WOT burst from reasonably low speed to, probably 75-80mph (but I'm guessing here).
2) If you do NOT have the latest version, then your AFR may be inverted. The latest version of redux will find that. Anyhting other than the latest version will just say "no data".
It would help if I can look at a log, and knew what version you are running.
Please let me know.
You can download the latest version here:
http://www.dslogredux.com/download.html
DSLogRedux.com
DSLogRedux.com
RE: Re: can someone help me
i do have the new version and after i posted i read a post that that told me what i was doing wrong. maybe i undersand i better now. thanks for the help
2007 GMC Sierra Vmax 6.0 3" magnaflow ehxaust, K&N CAI, Predator U7194
Grumpy_Aero_Guy
no problem.... still, feel free to post the csv, if you would like. I am happy to take a look at it.
DSLogRedux.com
DSLogRedux.com
when i get the new data i'll send it to you
