not reading codes
Posted: Sun Apr 20, 2008 2:06 pm
by kw5.9
predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
RE: not reading codes
Posted: Mon Apr 21, 2008 7:16 am
by Herculou
kw5.9 wrote:predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
Mine does the same thing, some codes it will read and some it won't . Have you done the KEY trick to get the codes? Turn the key to "run" 3 times and the codes will appear in the Odometer display.
You can try to clear the Try to clear the codes anyway. It might not read the codes, but it can still clear some of them.
Posted: Mon Apr 21, 2008 12:19 pm
by kw5.9
Thanks, i will try now, but it will give me code how do determine what the code means? Thanks again help, I am contemplating going to dealer this afternoon.
Posted: Mon Apr 21, 2008 1:36 pm
by Herculou
http://www.cumminsforum.com/forum/115229-post5.html
This web site has a lot of the codes and what thay are....
I am worried
Posted: Mon Apr 21, 2008 7:24 pm
by kw5.9
I put my truck in the shop, I took off the programs,the boostfooler,and the puck, they told me cylinders 1,2,3 were not firing, they questioned me about the velcro on the fuse box, for the puck(i fogot to take off)they asked if I had any kind of box on the truck, I told them I was the only owner of truck and had never had a box on there, I revised the predator about 2weeks ago with the new revision so I hope key counts are not going to be an issue,but can any one give me some words of advise so when they trow questions at me I know what the answer needs to be.
RE: I am worried
Posted: Mon Apr 21, 2008 10:22 pm
by Herculou
with only 2 weeks of the new version your "key counts" are going to be low, they may ask about that. Tell them you reset the computer trying to fix the problem. I believe (but I am not positive) all you need to do for that is to disconnect the battery for a few (10-15) minutes.
Posted: Mon Apr 21, 2008 10:36 pm
by kw5.9
cool!, I hope that works.. Do you think they can really prove anything?
Posted: Tue Apr 22, 2008 6:59 am
by Herculou
Not sure they could "prove" anything. If thay don't see it attached I don't see how they could...
Posted: Tue Apr 22, 2008 8:59 am
by kw5.9
hopefully the ecm dosent show anything on there that they can hammer me on
