Thinking of buying
Rc5522
Thinking of buying
Post by Rc5522 »
But before I buy I have a question.
2004 Ford Mustang GT
Cold air intake kit
75 mm Throttle body
After martket upper intake plenum
Cat back exhaust
off road H-pipe
Will the predator come with a specific tune for these mods or is it going to require multiple tunes/changes ?
Will it include the timing change in a tune or is it a seperate adjustment
As well as when I add a set of 3.73 gears is that seperate from the drop in tune's
Hey thanks in advance...
I ask here cause I'd rather get it from the horses mouth...
RE: Thinking of buying
The performance tune in the Predator will work fine with the mods you listed. The timing is advanced in the tune. You will need to change the parameter for your gears in the tool to fix your speedo. Its a simple change.
Return to “Predator Ford Gas”
