Trinity 2 LBZ
Trinity 2 LBZ
Does the trinity 2 support an 06 LBZ? I tried to flash the truck and it gives me an error after it tries to read the TCM. I think its 801?? Or it times out.
Re: Trinity 2 LBZ
skip the tcm when it asks, it is not supported.
tech@diablosport.com
Re: Trinity 2 LBZ
In order to skip it...I just write as a manual trans correct??
Re: Trinity 2 LBZ
that will work, or when it asks if you want to read the unknown tcm just click no.
Re: Trinity 2 LBZ
No option to change transmission or bypass TCM read.
Re: Trinity 2 LBZ
It won't reset since it isn't actually married correct???
Re: Trinity 2 LBZ
It seems you are still trying to read the tcm which is not going to work, you need to click cancel on the option to read the unknown module.
Re: Trinity 2 LBZ
I click cancel and it goes back to the main menu and when I try the tune again.. goes back to wanting to read the TCM again.
Re: Trinity 2 LBZ
please post the info.xml file from the T2 drive.
Re: Trinity 2 LBZ
I hope I did this right??
Re: Trinity 2 LBZ
the device is not up to date, please connect it to a pc and update it using our update agent software and then give it another shot.
Thank you.
Thank you.
Re: Trinity 2 LBZ
I must be doing something wrong. I update with wifi and it times out and when I'm trying to use the updater for PC and I'm sure I have the right drivers installed. Tool says it's up to date but still no luck on downloading tune. Is there some way to reset the tool and start from scratch maybe??
Re: Trinity 2 LBZ
so you update it with update agent on a pc and it says it is up to date?
Re: Trinity 2 LBZ
Actually, i see the issue.
We need to swap this device out.
Did you buy this new from us?
