I loaded the Predator into the truck and all went fine. I tried to start the truck and it won't even turn over. The digital dash says check gages. I tried to return to original backup and the Predator says it can not read the truck.
I need to get it running so I can use it for work. How can I force the original backup?
Loaded Predator in '06 Ford Diesel Truck doesn't turn over
RE: Re: Loaded Predator in
WOW! Excursionist was so much help with what I asked.
If your posts are not going to actually be any benefit, STAY OUT!
iwantmorepower
call Diablosport or email them with the info that comes up on the tuner when you press force and they will give you the code needed to force the tune
Re: Loaded Predator in '06 Ford Diesel Truck doesn't turn ov
What revision is on this Predator?mid1480 wrote:I loaded the Predator into the truck and all went fine. I tried to start the truck and it won't even turn over. The digital dash says check gages. I tried to return to original backup and the Predator says it can not read the truck.
