I got my brand new i3 on my network, used the wifi updater on the device at least 20 times now and every time it restarts and I search for an update there is another one. I do not believe its actually updating anything. I also tried doing the update through the PC update tool. It says there is an update, it installs it, I unplug the device after it reboots successfully and try the tool again and it says there is an update and the problem continues. So unless there are updates every 30 seconds, there is something wrong with my device.
What should I do here?
APP Info:
Vehicle: 2r04c
GUI: 2r01s
Installer: 2r01m
Updater: 2r01j
Logger: 2r01d
Database Info:
GUI: 2r00d
i3 Keeps "Updating"
Re: i3 Keeps "updating"
don't do it via wifi man... known issue, it will keep saying you have updates to do, etc....
you need to download/install the Update Agent software on your Windows PC/laptop.... connect the tool to your Windows pc/laptop... get it to the main menu... then start up the Updater program.... update the inTune to the latest updates...
once it reboots, the Updater program will show that it's up to date....
and that's it man...
then shut down the updater program and disconnect the intune from your computer...
done and good to go...
ferrarilambo12
Re: i3 Keeps "Updating"
The Update Agent 1.0 seems to do the same thing, every time I connect the device it says there is an update. Is it normal for the PC tool to do this? I just want to make sure before actually plugging this into my car.
yes, known issue with their update server... after you run the updater once or twice, then that's it... no need to do it anymore... good to go...
ferrarilambo12
Ok perfect, thank you so much for your help.
Hey I got the i3 and accidentally hit don’t allow when trying to launch the updater agent and now I can’t update how do I fix do I delete the updater file then re plug in the i3 anybody got ideas
what happens when you try to launch the update agent software now?
