Quick question, concerned on fuel supply
Posted: Fri Apr 26, 2019 4:22 pm
by jaysrippen
Good day, quick question: whats best to watch monitor while data logging to ensure im not running out of fuel supply/pressure while spraying NO2 in my LS3 camaro?
Fuel press/fuel trim/....??
Thanks, Jason
Re: Quick question, concerned on fuel supply
Posted: Sun Apr 28, 2019 2:44 am
by jaysrippen
Also when in logging fuel press it doesn’t change from 255kpa, like 37psi (idle to wot), seems low?
Posted: Mon Apr 29, 2019 7:43 am
well, you should really consider a wideband. Fuel trims are out the window as the pcm is no loner is total control of fueling when the kit starts spraying additional fuel.
Fuel pressure would be good to view but wont tell the whole story.
