7220 Stuck at Custom tune view
7220 Predator 2 (2008 Hummer H2 SUT) stuck at Custom tune view telling "no custom tune files..."
When pressing back it just goes to the root choosing between Tune, Info and Scan. Accessing the Tune section will give me the above notification...
https://drive.google.com/open?id=1UfHs4 ... AzWIsf8zfm
https://drive.google.com/open?id=1M2GuA ... gWQ55pdWY-
How to return to standard tune / custom tune selection?
Re: 7220 Stuck at Custom tune view
can you post the serial number please?
mikel wrote:can you post the serial number please?
SN: 201311555
you need to have a custom tune made for it, using the file it read out.
or were you planning to use the canned tune?
if so we need to correct the non stock condition.
My plan was to use the standard tune, but also set the tire size. This I'm not able to do currently. Can you help?mikel wrote:or were you planning to use the canned tune?
How do we correct the non stock condition?mikel wrote:or were you planning to use the canned tune?
OK, we'll get it going.
Please update the device so we can upload the reads and let me know once thats done.
Device is updated!mikel wrote:Please update the device so we can upload the reads and let me know once thats done.
Thanks, we're on it.
All set, update and it will download a stock file, then you'll load that to the vehicle then you may install the canned tunes.
Hi! I did as you directed and everything went well. Tomorrow I get to try the truck and see how it works.mikel wrote:All set, update and it will download a stock file, then you'll load that to the vehicle then you may install the canned tunes.
Thank you for great help!
Awesome, enjoy!
ohhh im having this issue right now
