How do i get my esp back on??
t00w0ngf00
I have 93 cai programmed on my 07 charger, i dont want my ESP to be off all the time. i go to quick adjust and turn it on, turn the key off and on and it says changed.... but it never turns back on. How do i get it to work again?
RE: How do i get my esp back on??
The ESP light is always on??
2013 SuperBee......................................................
t00w0ngf00
no the light is not always on, the diablo tune disables the esp on my car. i dont want it disabled unless i push the button on the console.
t00w0ngf00
Ok, just wondering. It actually is on (not disabled) but the threshold is much higher. As of now there is no way to have it like stock with the Diablo tune in it.
I don't remember a clear answer on that. Are the canned tunes the same as stock with "press and release"?
Stock (LX): Press and release the button.
-Straight line traction is disabled (you can spin the rear tires)
-Lateral intervention is relaxed. Both the point of intervention and the degree
-ABS is on.
Stock(LX): Press and hold the button (with car stopped).
-Straight line traction is disabled.
-Lateral intervention is disabled.
-ABS is on.
-ABS is on.
-ABS is on.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Actually with the press and hold, even with the Predator, I was unable to spin the tires yesterday. I was "breaking in" the new asphalt the city laid down and did a power brake job, and the TC still kicked in after a short while. I mean I was still able to make some smoke, but I wasn't able to maintain the spinning.
Eventually I was able to get the wheels spinning the same speed and get them to spin a little longer, but then hit the limiter. Went into Limp mode, threw the P0219 code. Not cool. Wish there was some way to completely disable the straight line but keep the Lateral and ABS
Have you tried the key turn trick? Driving along about 10 mph, turn the key like you are going to start the car again, after 2 seconds or so, Mr. Squiggles comes on and so does the BAS light. Turns off everything like the Predator, but you keep your ABS. Only works on some years thou (mid '06 and later I believe). It works good...better then any dash button pushing. I still think the ESP off via Predator works the best...but you lose ABS.
