by mistake deleted
youngmillion89
by mistake deleted
Post by youngmillion89 »
Hello everybody,
I've got some new issues with my "new" intune i1000.
I wanted to drag and drop the "tooned" file which was converted by "mikel" about one week ago.
When I was done with it, I delted the "tunes" folder from the intune by mistake.
So now my "tooned" file and my backup file is deleted and the i1000 says, that my car (2012 dodge charger srt8)
is not supported.
When I plug in the intune at the OBD Port of my car, the intune says that my can't be found (probably because of the deleted backup file)
Is there a way to get my backup?
Could you please help me?
Thanks you for your help.
Regards
Maxi
Re: by mistake deleted
deleting the tunes folder doesn't have any impact on how the device works.
Please post the current info.xml file from the device.
youngmillion89
attached the info.xml
Greetings
2 things, the tool needs to be updated as it is missing a file, and its not married to the vehicle so there is no backup being held currently.
youngmillion89
hi mikel,
update: the intune is now fine and it can find my car again :wink:
now here's the new (old) problem. Now the intune shows me
"too many sum dec" on the screen after I draged the file you converted me (pic attached)
Maybe the file you converted was for a wrong device.
Would you please take a second try.
Also attached are now the files I got from "diablotoona" again.
Please help me.
Thanks a lot!!!
Regards
is the backup file you posted here from the device after it read the vehicle again?
youngmillion89
the backup file was the old one, which I have recieved from the "Diablotoona" so it was a
backup for the t1000 i guess.
now I attached the backup that was made, after the intune is "working again" if you need this.
youngmillion89
Hey mike,
Could you already convert it?
Here you go.
