i3 software update TCM question
kgry
Post by kgry »
I updated the software on my i3 after not using it since last November. I went to update my TCM tune and I'm not seeing the firm or hard options. I now see sliders to adjust the firmness per gear for normal or tow/haul. I remember just having the option to select firm or hard. Has that moved to a different menu?
Re: i3 software update TCM question
you are in the modify parameter menu if you see that, but you should have seen the tcm tunes before you got there.
Go to advanced tune and select a pcm tune then a tcm tune.
kgry
Post by kgry »
Ah thank you. It's been a while. Forgot you need to tap standard tune again to get the TCM options.
