2013 Mustang 5.0 No Start/ All lights on dash on
Hello, I was attempting to put a previous tune I've already ran and during the exporting file at 98% all the lights on the dash turned on and the car started showing service advance track, service charging system, security flashing. Export file went to 100% and said it was completed. Try starting the car and I get nothing, all those lights and service codes are still going and it's showing my vehicle mileage as lines. I don't know what to do, I've successfully tuned this car several times already. When I hook the diablosport up and hit install tune, it just freezes every single time now. It won't even let me check fault codes. Please Help, thank you attached are pictures of the dash when the key is forward.
Re: 2013 Mustang 5.0 No Start/ All lights on dash on
I will have to get it towed to Ford tomorrow if I can't get any info from anyone. Thanks
Please give us a call with the tool powered up in the vehicle so we can try to recover it asap, 561-908-0040 x4
Thanks Mike, I get off work around 3:30 and will be home by 4:15. I drove my other car today but I'll call as soon as I get home if it's ok.
Hey Mike, sorry to bother. I wanted to add that when the key is forward with no start condition, the security light also blinks. I noticed it blinks a numeral value. That value is 1 and 6 which means the pats system cannot communicate with the pcm. Thanks
ideally we can force the device to write the stock tune back to it.
Thanks a lot Mike to you and your team. Forced restored the backup then reloaded the tune. Works good now. I really appreciate it, would of been stupid of me to bring it to a dealer. If anyone reads this and has the same issues, contact diablosport directly first, no one else! And go from there. Thank you!
Glad to hear it.
