120 HP in LBZ?
tim_hinz
120 HP in LBZ?
Post by tim_hinz »
Has anyone on here tried the 120HP mode on an 06 LBZ? I'd like to try it, but my brother tried it on his 05 and it limped the tranny. Just wondering if I should be expecting the same result?
RE: 120 HP in LBZ?
Shouldnt be a problem as long as you are not towing...but it does make an a$$ load of torque...
chrisshipley
RE: 120 HP in LBZ?
Post by chrisshipley »
120 hp is all that I run. I do have a 5 inch turbo back exhaust and the BD exhaust manifold. Never had any problems. Would not suggest without an after market exhaust.
rydnhi4x4
RE: 120 HP in LBZ?
Post by rydnhi4x4 »
I also run the 120 Tune. Some say you will limp the tranny on 120, but I have also heard of guys limping the tranny on the 65 Tune.
It all depends on how you drive your truck.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
yas305
RE: 120 HP in LBZ?
Post by yas305 »
I have a 2007 2500 LBZ and i ran the 120 Tune and after i did that the truck some times make like a tacking sound the truck is compleatly stock why would this be?
