2008 Jeep grand Cherokee, 5.7 Hemi
Instead of asking you a bunch of questions about Advanced settings on the I3,
Would you be able to send me complete users manual?
Thanks in Advance
Doug
Users manual
Re: Users manual
Re: Users manual
Thanks... but I already have what I would call the quick reference guide. Not even needed, really.
The unit is easy to use.
If I go into modify parameters - all I see is pressure calibration, tire size, traction control.
What happened to the other adjustments ?
Also, Front LP threshold and rear LP threshold. both set to 26 PSI. If I try to set these i3 just re-boots.
Cant be used...
If I set A parameter, and then I go back at a later date, how can I see my last setting?
So I assume you don’t have any more advanced settings manual to help with setting different parameters ?
Doug
Cant be used...
Doug
