i2 Updater problem
Posted: Fri Jun 07, 2019 10:16 pm
by Rconnell
Haven’t updated in a while. My old ignition app wouldn’t work and I found it was replaced with update agent 1.0 but I went too far in attempting to delete the old app and files so my pc wouldn’t be cluttered and now I’m missing the files in the i2 after clicking windows. From the i2 file with the device connected to my lap top, I go updater>windows>then don’t see “inTuneUpdater2.exe”. How do I get this restored in the device so that I can update?
In addition, what’s the difference between doing the above method vs connecting the i2 with WiFi and clicking “check for updates”? Are these two different functions? Any direction is much appreciated.
Re: i2 Updater problem
Posted: Sat Jun 08, 2019 10:34 am
no man.. you won't have the updater on the intune anymore.. you just download and install the new Update Agent program on your PC... then you connect your intune to your PC.. let it boot up to the main menu/screen... then you launch the Ignition Updater (Update Agent) program on your PC... it's in the Powerteq menu on your computer.
Posted: Sat Jun 08, 2019 12:11 pm
by Rconnell
Ok, that clears that up. Thank you. I successfully completed the installation and the device appears to have updated.
So what exactly is happening when I connect the i2 to WiFi and select WiFi config>WiFi setup>enter WiFi password>click yes to check for updates? Is this only informing me that updates are available but still must use the update agent to actually install updates? Was thinking I did this before without running the updater on my pc and it looked like it downloaded updates just through the i2 connected to WiFi? Are these two different operations?
Posted: Sat Jun 08, 2019 12:14 pm
it would install updates via wifi.. but in my experience, it does not always get all available updates that way... you're better off using the updater program on your pc to do updates.
Posted: Sat Jun 08, 2019 7:14 pm
by Rconnell
Ok, thanks. You’re customer service is excellent.
