Gateway Bypass Cable Video Wrong 2018/19
tdjacw
Post by tdjacw »
https://youtu.be/owaQ33DzcWU
This Video states the Green Module is located directly behind the OBD2 port. However the Video shows it under the passenger kick panel.
They need to fix this very confusion. Even the instructions I received stated this.
tdjacw
Re: Gateway Bypass Cable Video Wrong 2018/19
Post by tdjacw »
So no answer from customer support about the gateway bypass cable install Video and instructions being wrong. However I just installed the cable and PCM and can confirm the Video/instructions are incorrect. The green buss connector is located under the glove box NOT DIRECTLY BEHIND THE OBD2 port. This could be really confusing to folks. They really need to correct this as every time I watched the Video I kept second guessing myself.
Looking into why the vid is different.
Return to “General Questions”
