Charger 2014r 6.4 superbee - issue when calibrate
thorgalak
Post by thorgalak »
Hi
I have problem when calibrate. it goes to 99% asks to OFF/ON ignition then it goes to PCM update and gives error "an error occurred when calibrating your vehicle". In attachment file info.xml.
Re: Charger 2014r 6.4 superbee - issue when calibrate
are you sure you are performing the key cycle properly?
thorgalak
Post by thorgalak »
Yes, we are going to "run" on the key fob, and at the end we are going off and then on.
thorgalak
Post by thorgalak »
Any update on this ? can we have some support here ? The tool updated, updated the calibration file using the agent on PC, then when going to car going thruu the proces it ends saying that during the calibration error occured. Please help
Any chance you can give us a call so we can try resetting the tuner and starting fresh?
thorgalak
Post by thorgalak »
mikel wrote:Any chance you can give us a call so we can try resetting the tuner and starting fresh?
HI, there is a little problem , because i live in Poland , so we have like 6h time difference. Is there any other way to reset the device to stock ? Do one more time updates with agent ?
