Adding Gauge Inputs
This section of the forum is for discussion relating to the use of the T2 EX tuner/monitor on GM vehicles.
Tomfoggy
Adding Gauge Inputs
Post by Tomfoggy »
I have T2 #9245 for 2013 GMC Yukon 6.2.
I would like to add 2 inputs to read out on my display if possible.
Wide Band O2 sensor readings and Boost/ Vacuum from a vacuum/boost intake sensor.
What item would I need to purchase and is it possible. This way I don't have to "install" new
gauges and gauge pods. I could just use my existing T2 Platinum Dashboard
Re: Adding Gauge Inputs
Check out the EAS option on our website, you'll need the analog input cable for the WB and we offer several different pressure sensors.
tech@diablosport.com
