since upgrage cant upload original tune to pred
ghettofied
im not sure what info would be pertinent but i found all this stuff
serial - d007053
part - u7146
version - 9r02
hardware - univ-rev2
bus - sci can
calid - cvaf1a4hex
ever since i upgraded my pred i cant flash a tune to the eec it trys to save a backup of the original tune and says its already been tuned and cant so i try to load my original tune from the the computer and it says it cant read the format PLEASE HELP what should i do
serial - d007053
part - u7146
version - 9r02
bus - sci can
calid - cvaf1a4hex
lazorrazor
RE: since upgrage cant upload original tune to pred
did you return you vehicle back to original stock tune before updating?
LaZoRRaZoR
Re: RE: since upgrage cant upload original tune to pred
Yeah, that is the question that needs to be answered.lazorrazor wrote:did you return you vehicle back to original stock tune before updating?
ghettofied
no i didnt know i had to so what can i do to fix itmikel wrote:Yeah, that is the question that needs to be answered.lazorrazor wrote:did you return you vehicle back to original stock tune before updating?
That sucks I believe you have to go to the dealer and reflash the ecm. After that if you show the paper work for that Diablo might be able to unlock your Predator I am guessing here.ghettofied wrote:no i didnt know i had to so what can i do to fix itmikel wrote:Yeah, that is the question that needs to be answered.lazorrazor wrote:did you return you vehicle back to original stock tune before updating?
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
RE: Re: RE: since upgrage cant upload original tune to pred
Go back to whatever revision you were on, and then restore the backup, then update the Predator.
ghettofied
Re: RE: Re: RE: since upgrage cant upload original tune to p
how do i go about that im not postive what revision i was on before i didnt look i am guessing 7r50d but i got no idea anyway how would i go back i dont have the crom file would you need to send it to me or is there somewhere to download them i havent found thanks for your help because its frusterating to spend 350 dollers on something for it to be uselessmikel wrote:Go back to whatever revision you were on, and then restore the backup, then update the Predator.
ghettofied
okay i tried this and as soon as it tried to start downloading the crom it gives an error message "you are trying to install an outdated crom file vist diablosport.com for the latest revision"
so now what do i do?
lazorrazor
RE: Re: RE: Re: RE: since upgrage cant upload original tune
Hey...you can still go to the dealer and have them flash your ecm right? Than you can install r50d and you all good! Right??
LaZoRRaZoR
lazorrazor
Re: RE: Re: RE: Re: RE: since upgrage cant upload original t
Never mind, I just remembered, it wont let you install older version.lazorrazor wrote:Hey...you can still go to the dealer and have them flash your ecm right? Than you can install r50d and you all good! Right??
LaZoRRaZoR
Set the DSDownloader to the legacy connection and set it to the same com port it is on now, then do the update and it will work.ghettofied wrote:mikel wrote:Go back to whatever revision you were on, and then restore the backup, then update the Predator.
ghettofied
Close DSDL and reopen in Legacy Mode, then try again.
If you just switched to Legacy without closing, it maintains the auto detect function.
ghettofied
i did that same message tried it with compressed send on and off freedom send on and off com protocal normal and class 2 auto detect on and off legacy connect on and off restarting the dsdownloader each timemikel wrote:Close DSDL and reopen in Legacy Mode, then try again.
i still get the same "you are attempting to install an outdated...." is there anything else i can try? thank you
