2005 programmer problem after truck came back from th dealer
Posted: Thu May 29, 2008 7:14 pm
by 95HarleyBadboy
1) The part# sticker has a handwritten 2005, then under it a ford 6.0
2) Revision R84
3) 2005 Ford F-350 6.0L
So I have had my predator in for the better part of 2+ years. Absolutely loved it. Took my truck into the dealer to have some issues addressed before my warrentee expires, and that's where everything fell to pieces. The warrentee bill ended up being $32,000.00, Thanks to a Horrible diesel tech. So I am happy as heck because Ford just basically rebuilt my whole truck. I get home and go to install my programmer and it tells me to contact Diablo tech line. It gave me the following information:
CalID 'ARZ2ALO1
VXCF4NK.Hex*
TQCIONB.Hex*
One thing the dealer replaced that I think made the difference was a total new computer for my truck???
So what does this mean for me and my truck, I REALLY miss my Predator
RE: 2005 programmer problem after truck came back from th de
Posted: Thu May 29, 2008 7:46 pm
by PSDPlayer
It has the latest of the ZZR series processors. It has the newest of the trans strategies to address some tow/haul shifting problems. You probably need to download the latest version to your predator as it supports all of the newest calibrations.
Posted: Fri May 30, 2008 9:14 am
Yeah, update to 8r10 then 9r03 and you're good to go.
Posted: Fri May 30, 2008 12:58 pm
by 95HarleyBadboy
Ok I tried to do that and on my computer it says the download was successful, However on the programmer it tells me that the tool was improperly upgraded, and to downgrade to the previous version.
What now????
Posted: Fri May 30, 2008 2:33 pm
OK, you did not restore the stock tune to the truck before you took it to the dealer.
To fix this, you'll need first go back to the 7r84 revision, then fax us the paperwork from the dealer with the reflash listed.
Then call us with the tool powered up, so we can reset it, then you can update it and tune the truck.
Mike
Posted: Fri May 30, 2008 5:00 pm
by 95HarleyBadboy
I am 99% sure I uninstalled the programmer prior, but maybe not. Any rate they didn't flash the CPU, they replaced it.
The 7r84 program is reinstalled.
Posted: Fri May 30, 2008 5:07 pm
by 95HarleyBadboy
What is the Fax # to where I can fax the portion of my bill stating they replaced the computer?
OK, then reinstall the backup file, and then update, and reinstall.
Posted: Mon Jun 02, 2008 12:35 pm
by 95HarleyBadboy
Tryed to reinstall the backup file into my truck with 100% no luck, so obviously not only am I an idiot, but one heck of a lucky one. I must have forgot to reinstall the backup file the last time it was towed to the dealer. Noe I am saying I am lucky because they could have voided my warrentee and I would have had to pay for all the work done.
So now that we have established this, does that mean I need to buy a new programmer?
Posted: Mon Jun 02, 2008 6:35 pm
by 95HarleyBadboy
HOLY SMOKES DIABLO YOU ROCK,
All I had to do was fax in the work order stating my CPU was replaced, call Diablo's Tech support and they literally had me back up and running in 5 minutes. AWSOME
