Will this cam run with a canned 93 Octane Tune in a 2016 5.7 Hemi/6-Speed?
https://www.compcams.com/stage-1-hrt-21 ... -2009.html
Engine Family:Dodge 5.7L and 6.4L HEMI w/ VVT (2010+)
RPM Operating Range:1700-6500
Grind Number:LST269HR14
Cam Type:Hydraulic Roller
Lifter Style:Hydraulic Roller
Camshaft Series:HRT
Stage:1
Valve Springs Required:No
Camshaft Material:Billet Steel
Advertised Intake Duration:269
Advertised Exhaust Duration:271
Intake Duration at .050 Inch Lift:216
Exhaust Duration at .050 Inch Lift:222
Intake Valve Lift:.520
Exhaust Valve Lift:.515
Lobe Separation:114
Will this cam run with a canned 93 Octane Tune?
May the bridges I burn light way!
Re: Will this cam run with a canned 93 Octane Tune?
IMO, ANY cam swap will require custom tuning.
if you are looking to avoid custom tuning for whatever reason, you should avoid a cam swap
Also, I strongly believe for the most part that if it doesn't require tuning, it is not at all worth the effort of ripping your motor apart to install it.
tech@diablosport.com
Understand, but will it run with the 93 Octane tune until I can get someone to tune it?
I dont know. I highly doubt it.
Even if it does, its likely going to want to stall and run rather poorly at best.
The 93 tune make no changes relevant to a cam swap, so it will run no differently than it will on the stock tune.
Should be able to get a base email tune from your tuner prior to the install to at least try to make it drivable.
Thanks. I'm not sure I'm going to do the cam upgrade.
What changes does the canned 93 Octane tune actually change concerning the engine and add on modifications?
Changes include WOT spark and WOT fueling adjustments, torque management, and more.
