Can't export LTW?
Can't export LTW?
Mike, I need help. Export LTW is grayed out on my i2. I need to send it to you to see whats done. I'm having issues with PATS and the Bypass module, and I need to know if either one is disabled.
I get the Theft light solid when I crank the ignition key without a second car attached, but when I jump it, it starts fine. Thinking the PATS is acting up.
And since I put on the Kenne Bell I'm not getting any boost. Their Tech support told me to check the boost reference, which I'm guessing is the vacuum line to the valve, which runs from the bypass module.
Mechanically, its fine. Runs okay, sounds good, vacuum is solid 20-25in/hg at idle. WOT goes to 0 vacuum and just creeps to maybe half a pound of boost.
https://youtu.be/yuVpP4yBPhE
Re: Can't export LTW?
Not sure what you mean...are you trying to use DSDL??
On i2, the backup and LTW are on the i2 drive in the tunes folder, no software required to access them
Yeah, I'm an idiot. I was trying to export it from the tool.
Anyway, can you check and see what he disabled in this tune? I need PATS, Boost limiting and EGR turned off. Pretty sure he did the second 2 but not PATS.
Thanks.
Thanks.
pats disabled here
Thanks. Are the other things turned off? Don’t really care about the EGR since I still have it, but the boost limiter is a problem.
egr was not off.
Near as I can tell the bypass is disabled.
Thanks. Lets see if this works.
Seems good... idle is a bit high, but I can adjust that by closing the throttle stop screw. Definitely hope the bypass module is disabled though, because the part that goes to the actuator is now capped.
it is.
Still flashing the Theft light and won’t start without a jump. I’m getting closer to condemning the ECU.
In the other hand, when I do get it running, it’s running fine. In Park the idle is high, but once it in gear it drops.
let me see the last tune written from the device.
Tell me that my dumb ass loaded the wrong tune.
Yeah thats not the file I made, doesnt have PATS disabled.
Will it work if I rename the file so I can’t screw up? The i2s screen is so small that it doesn’t show the whole file names. So I’m guessing which is which.
I renamed it here.
