2016 C7 - Turn Off Torque Management?
challenger01
Post by challenger01 »
Is there an option for me as a end user to turn off "torque management" on my 2016 C7 with my Intune?
I can't seem to find it if there is.
Thanks in advance for your help.
Re: 2016 C7 - Turn Off Torque Management?
There is no end-user Engine torque management setting that you can adjust.. it's already done in the preset canned tune...
If you have a manual tranny, well, then there is no torque management, so nothing to do for the tranny...
if you have an automatic tranny, then yes, there should be a setting for the TCM/tranny torque management that you can enable or disable...
Make sure your inTune is fully updated to all of the latest updates..
Then you'd go to Tune Vehicle - Advanced Mode...
select the ECM/engine tune you want to install..
then select the TCM/tranny tune you want to install..
when it asks you if you want to Modify the TCM/tranny tune, select yes/ok/green checkmark.. .and then you should get into the Modify Tune menu...
and there should be a torque management menu/setting in there that you can go to and disable the torque management...
then exit back out, and install/apply the tunes...
challenger01
Thanks!
challenger01
I couldn't find the toque management option as you suggested in your above response.
So I updated the tuner, unloaded the tune, then reloaded the tune and still there is not an option for Torque Management available.
Am i missing something?
