I'm trying to add a Boost gauge through the E.A.S. with a gm style 3 bar Map. There is no negative in the set up, how can I do this, I'm getting screwy numbers.
And yes I know there is a Boost gauge that is created from the MAP and Barometer, but I here that does not show up in Data Viewer....
oh dear nor does E.A.S...... but respectfully I know you guys are working on that one lol.
Configure 3 bar gm map for boost guage
- MagsTuning
Re: Configure 3 bar gm map for boost guage
Dragon23 wrote:I'm trying to add a Boost gauge through the E.A.S. with a gm style 3 bar Map. There is no negative in the set up, how can I do this, I'm getting screwy numbers.
Do you have your MAP data/offsets correct when setting up the PID?
As far as I’ve found
The slope is 329.41
And the intersect is -6.36
From the sensor specs
I’ve been putting in
0 = 0.35v
44= 4.98 v
Is the PID boost on the Trinity synthesized it use to be called MAP-BARO
The slope is 329.41
0 = 0.35v
44= 4.98 v
Okay it is not rocket science you need to input
0v= -14.503
5v= 29.88
But you need to put a negative in front of the 14 HOW do you do this on this unit ?
The T 1000 was capable. watch video. Can you please give the same, or am I missing something. Did you hire the coder from flappy bird ?
https://www.speedysgarage.net/challenge ... ar_map.htm
0v= -14.503
5v= 29.88
We are looking into a solution for this.
OK, I have emailed you a fix for this.mikel wrote:We are looking into a solution for this.
Let me know once you've had a chance to try this.
I just did right now, yep that’s it it reads 0 with engine off and vacuum when running about -6
I’m not able to check boost It’s off the road for winter all indications is it will display correctly
Thank you.
Thank you.
Glad to hear it, enjoy.
