trans tune
trans tune
on a 2019 ram new body is there no trans tuning available other than custom tuning?
- MagsTuning
Re: trans tune
I haven't done any tuning on a 2019 but I'd think there should at least be an option for adjusting shift points.
What are you wanting adjusted?
Re: trans tune
maybe a little pressure and change the shift points in the higher gears.maybe try to make it shift a little faster
- MagsTuning
Re: trans tune
You should have adjusts under "advance tune" then "modify parameters". I don't mess with the handheld side much only adjustments available to me in CMR.
Re: trans tune
I haven't been able to find it if it's there. it has a modify stock tune in the tcm section but goes nowhere.
