2016 Camaro SS AFM
2016 Camaro SS AFM
Hello, I have a Trinity T1000 with 1R14B revision on it. I uploaded a 91 Octane tune with a hard shift trans tune, but it doesn’t seem to turn off my AFM? The light goes green and shows V4 mode still, I tried with a modified stock tune and it does the same thing. Do you know what’s going on? Thanks
Re: 2016 Camaro SS AFM
you are selecting the option for AFM off then installing the tune after that?
if souse the DSDownloader to export the last tune written and post it here.
it doesn't get disabled automatically man... you have to select to Modify the 91 octane tune and disable the setting yourself, and then install the tune...
I am modifying the tune and selecting AFM/DOD off in the engine parameters. I have changed the tune 3 times to try and see what the problem was. Still goes into V4.
I dont recall f this was a bug on that application, but it was not off.
Load the attached custom tune and it will be disabled.
- PCM_673677677821_afm.grg
- (110.5 KiB) Downloaded 369 times
Thank you so much highly appreciated!
