1999 - 2000 silvarado tunes
morganboss05
i just bought a 5.3 ls truck and i need a tune for it it came with a diablosport 2 please can some one help me with tuning
Re: 1999 - 2000 silvarado tunes
connect it to the truck and select a tune to install, and install/apply it...
Anything aftermarket installed in the vehicle? i.e did not come from the factory?
You need to make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
morganboss05
06MonteSS wrote:connect it to the truck and select a tune to install, and install/apply it...
i know that i was wondering if anyone had a tune to improve throttle response and and acceleration
the preloaded tunes will do what you are looking for...
What happens if you operate heater or open/close doors or windows
it will create a voltage drop and interrupt the tool in the middle of flashing/installing the tune and could brick your ecm
